TPMS relearn tool or air out on a 2011
Old 11-06-2015, 11:11 PM
  #31
LEN
LEN's Avatar
Angry tpms
I have a 2011 what the hell is a tpms?
LEN is offline
Old 11-07-2015, 02:13 AM
  #32
Tire Pressure Monitoring System. Lots of info on it via a search on Google.
whopper is offline
Old 06-05-2017, 01:25 PM
  #33
Beanie's Avatar
One more variation...
Both key fobs on my '08 LS went south. Cost to replace (in 2015): $100- ea., plus $75- ea. to program. A local audio/ alarm shop was offering an entire Carbine system (installation included) for about the same price. Replacement fobs: $39- ea. including programming. Went for it. Found out later that the Carbine fobs wouldn't activate the TPMS re-learn mode. Bought a "replacement" GM fob (no P/N stamped on back), different dealer (Tracy, CA) programmed it for free -- bottom line: it gets the system into learn mode. Only problem: the air down / up procedure doesn't work -- still have to use a re-learn tool (next purchase). Being an '08, the procedure should work per the manual, but no. Hope this helps someone -- Beanie
Beanie is offline
Old 06-05-2017, 02:02 PM
  #34
Technical Moderator
Being an 08 there is a TSB on how to fix it. Yours was probably a rental that had it turned off.
donbrew is offline
HHRclarke
"How To" Tutorial Library
34
07-20-2023 04:53 PM
66chevelle
04-10-2015 04:53 PM
HHR_SS_QC
Tires & Wheels
08-26-2014 03:59 AM
Jettin169
01-23-2013 03:55 PM
BlackknighT
08-19-2011 07:15 PM
Quick Reply: TPMS relearn tool or air out on a 2011
