Maf sensor cleaning
Old Jun 11, 2017 | 09:37 PM
hurst2001's Avatar
Maf sensor cleaning
Where do you spray the sensor to clean it ? In the square opening? Got 2.2 engine 2007
Old Jun 12, 2017 | 06:29 AM
Exactly, a squirt of MAFcleaner in the little square hole, let it dry and ensue you install it in the correct direction.
Old Jun 13, 2017 | 09:38 AM
hurst2001's Avatar
Ok just cleaned it and notice that back of the maf you see some slits I spray maf cleaner there too .. because the little square hole I didn't see any thin wire there ? Do you have to take it apart ? Also once you unplug it , it takes time to relearn your driving habits?
Just someone shed some light on thanks
Old Jun 13, 2017 | 11:18 AM
Does this help? I think this is similar to ours.
The way the MAF works: it measures the current required to keep the heated wire at a set temperature, thus indirectly measuring the air mass passing over it. Obviously more complicated than that.
1937Wag77
Dec 28, 2014 08:39 PM
bertoswimmer
Aug 13, 2014 02:01 PM
jlh152
2.4L Performance Tech
Feb 15, 2014 09:03 PM
Blue Beast (aka Boydie)
Fuel Economy - Hypermiling
Jun 5, 2013 08:42 AM
daddy2isaiah04
2.2L Performance Tech
Jul 17, 2011 12:31 AM
