2007 LT 2.2 Magnaflow pictures
Good evening all, just installed my used Magnaflow system, love how it sounds and it only took me literally 45 minutes. I had to cut the bolts holding the resonator on, then cut the stock tubing at the bend by the gas tank, but easy enough.
Here are some pictures.
There's this from ZZP
Click to get that catalytic converter and if you have an automatic transmission
Ecotec Parts 2.5 inch Stainless 2.2L Downpipe
Or this 2 1/4 mandrel bent pipe in stainless steel
https://www.ebay.ca/itm/321612653591
It has a Magnaflow catalytic converter!
I would suggest going with the package deal from ZZP that includes the downpipe with header - either long tube , mid tube or short tube. Might as well do it all lol
and get one with the high flow cat
