Engine Code P0011
Old 05-22-2012, 09:42 PM
bigboss2010's Avatar
Engine Code P0011
I have read the articles about the Camshaft Actuator being bad, is the reason for this code being thrown. Can anyone tell me if it is ok to continue driving my car until I can fix the problem? It is my only vehicle and I will have to do the repair myself when I have the funds. Just wanted to make sure I'm not going to shell my motor or anything. Thanks for any information.
bigboss2010 is offline
Old 05-23-2012, 09:30 AM
If you were to call your local Chevrolet dealership's service department, they should be able to provide you with the information you are seeking about your vehicle. Depending on the year of your HHR, this might be something that is covered under the Powertrain warranty.
Last edited by ChevroletCustomerService; 05-23-2012 at 09:32 AM. Reason: Additional information
ChevroletCustomerService is offline
Old 05-23-2012, 12:52 PM
ChevyMgr's Avatar
Do you mean camshaft actuator solenoid?
Nobody can say for sure you won't have trouble due to the CEL. It's up to the ECM gods as to whether they want to throw you into "reduced engine power".
ChevyMgr is offline
Old 05-23-2012, 01:02 PM
Okay, thanks for the information, and yes I meant the Camshaft Actuator Solenoid. I have a replacement on the way.
gag
04-12-2024 07:13 AM
DASH0071972@
23
07-01-2015 12:31 PM
chevhhrdummy
09-30-2014 07:48 PM
Sno White
10-03-2012 07:05 PM
mroney
08-23-2011 11:21 PM
Quick Reply: Engine Code P0011
