Loud Humming Noise?
Old 07-08-2011, 07:11 PM
DrummerHHR's Avatar
Question Loud Humming Noise?
All of a sudden I have a loud humming noise that seems to get louder as I accelerate. At first I thought it was tire noise, but it isn't. It seems to be coming from the rear of the vehicle. It is really annoying at high speeds. Has anyone else had this occur, and if so, what did it turn out to be?
It's a 2007 2.4 LT.
DrummerHHR is offline
Old 07-08-2011, 07:54 PM
Technical Moderator
You did look under the car for captured grocery bags etc.? It is not the "open rear window,closed front window" thing? Door gaskets, door not fully closed? Remote possibilities; Fuel pump, wheel covers, wheel bearings? I'm out.
donbrew is offline
Old 07-08-2011, 07:57 PM
ballplr's Avatar
my guess is you have a bad wheel bearing
ballplr is offline
Old 07-08-2011, 08:00 PM
Well first check the obvious things, stick your head under the back end to see if you've picked up something off the road, then look for anything that might be jarred loose. I once had a tremendous noise coming from underneath that turned out to be a plastic bag wrapped around the axle, sounds stupid but it gave me a serious "what the hell is that?!" moment.
Also check the exhaust, it might be loose in its rear hanger and vibrating up against the under body. Probably the biggest thing to check though is the rear wheel bearings, if you don't find anything else, jack it up safely and spin the rear wheels listening for bearing noise. Or have it checked out by your dealer/mechanic.
843de is offline
Old 07-08-2011, 09:14 PM
I agree with all that has been suggested so far...... Wondering how you ruled out tire noise though. You may want to rotate tires and see if there's any change..... Unless you already did that.
Greybeard999 is offline
Old 07-09-2011, 12:46 AM
Zagohhr's Avatar
x2...
Zagohhr is offline
Old 07-11-2011, 11:49 AM
Dear DrummerHHR,
I read through your post about the humming noise that you are experiencing as of this past Friday. How are things going with this? Did you decide to look for the suspects that the members of the forum recommended or did you make an appointment with the dealership?
Sincerely,
ChevroletCustomerService is offline
Old 07-11-2011, 12:31 PM
ChevyMgr's Avatar
If it is not a tire, most likely a hub bearing. If you are under 100K it's covered for free by power train warranty.
ChevyMgr is offline
QbanBuc
06-28-2015 11:11 AM
Gregs
10-01-2013 04:04 PM
futureladycop227
07-17-2013 01:47 AM
mikeylikesit105
06-22-2011 08:58 AM
Lake Runner
12-04-2010 07:45 PM
Quick Reply: Loud Humming Noise?
