No crank no start.
No crank no start.
Hello all the dreaded no crank no start
-fuses are good
-recall has been done (2014)
-battery is good and getting power to the fuse box
-security light is not on
- starter solenoid is functioning
- fuel pump is functioning
-no check engine light
background info. Car has been sitting for well over 2 years waiting on a trans. I wasn’t here when it first broke. Trans has been replaced now and I’ve got it back together as it was taken apart. I get dash lights and hear relays click. I can apply direct power to the starter solenoid and it’ll turn over but no fuel pump. If I jump over the fuel pump relay it’ll work.
it’s acting like it’s in a security shut out. However I haven’t got a security light. Also wipers don’t work as well as headlights.No check engine light I won’t have my scan tool till tomorrow about noon. So I can’t see any codes.
any help is appreciated thanks
-fuses are good
battery is brand new. Also on a jump pack to keep it in tip top shape while testing. fuses have been tested with a test light and multimeter.
