Cooling fan
Old 07-10-2015, 11:39 PM
Patr's Avatar
Cooling fan
Replaced cooling fan new. Still doesn't work relay good now what ??
Patr is offline
Old 07-11-2015, 12:25 AM
bobojay's Avatar
Getting power to the fan?
bobojay is offline
Old 07-11-2015, 05:00 AM
Year and model would help.
Regular HHR's and SS's have different cooling fan circuitry, so it could be different things wrong based on what car you have.
Mods. Could we get this moved to the correct forum section ?
firemangeorge is offline
Old 07-11-2015, 09:47 AM
Moved, as suggested. :)
whopper is offline
Old 07-11-2015, 05:03 PM
Check the fuse box ensure the halves are tight, check the relays and fuses, ensure they are pressed in tight, check the ground wires clean and tight.
How is your thermostat, it could be stuck open so the sensor for the fan never sees 217degrees
Oldblue is offline
Old 07-11-2015, 06:43 PM
Patr's Avatar
No power
Patr is offline
Old 07-11-2015, 06:53 PM
Does the fan work when you turn on the A/C?
Oldblue is offline
Old 07-12-2015, 01:56 AM
Lucky's Avatar
I'm guessing it's not an ss so I would check the 30 amp fuse. Main power to the fan motor. Here is a wiring diagram.
Lucky is offline
Old 07-13-2015, 03:37 PM
Technical Moderator
If the relay is good and there is no power at the fan doesn't logic tell us that there is a wiring problem? Maybe the connector is bad? Maybe a bad ground?
donbrew is offline
Old 07-02-2022, 01:12 AM
LuisConde's Avatar
My fan doesn't turn on when I turn on the AC, in fact it doesn't turn on by itself either, I need to bring the hhr without a thermostat so it doesn't get hot, what could be happening???
What do you think is "hot"?
Over 180F is normal, the fan should turn on at 219F. Hot is over 220F.
Without a t-stat Your AC probably doesn't run. I bet that you failed to mention a CheckEngineLight.
LuisConde is offline
Quick Reply: Cooling fan
