Stuck oil filter cap
Old 11-30-2016, 03:27 AM
Danman03's Avatar
Well, as usual I decided to work on my car and something went wrong. I was doing a routine oil change and the oil filter cap is stuck. The cap has rounded off to where the socket isn't getting the grip it needs. I really don't feel like spending hundreds of dollars at a shop for a $15 part. So, does anyone have any DIY tips? I was thinking of piercing the cap and then using a screwdriver and hammer to see if I can get it loose. Another option I saw was to heat a 31mm socket and basically melt it onto the cap. Any help would be greatly appreciative!
Danman03 is offline
Old 11-30-2016, 07:08 AM
Channelock pliers worked for me
The OEM cap is 32mm but can get rounded of if you use an adjustable wrench or 1 1/4 inch socket
Oldblue is online now
Old 11-30-2016, 07:45 AM
aradmahogany's Avatar
Order this first!!!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
aradmahogany is offline
Old 11-30-2016, 08:36 AM
Danman03's Avatar
I tried the channel locks, but can't get it to budge.
Danman03 is offline
Danman03's Avatar
Originally Posted by aradmahogany
I already have an oil filter
Danman03 is offline
Old 11-30-2016, 09:03 AM
Yes but that comes with the oil filter cap.
Old 11-30-2016, 10:09 AM
And it is cheap for the combo! you will get a basically free filter for the next oil change and you will get the OEM green oil filter cap O-Ring that (debated by some) doesn't need to be changed with every oil change. I have gone through many oil changes since buying that cap and not a hint of a leak without changing the o ring.
Old 11-30-2016, 10:11 AM
On top of that, unless you did it and dint realize, I would go to wherever you last had the oil changed and give them a few words... and not go back there after that LOL
Old 11-30-2016, 11:25 AM
Danman03's Avatar
Yeah that's what I'm thinking of doing. I'm probably 75% sure the shop I took it to last cross threaded the cap back on. I took an impact wrench to this sucker and it still won't budge. I just called a tow and I'm going to take it a shop
Danman03 is offline
Old 11-30-2016, 12:21 PM
Technical Moderator
Who rounded the cover off?
If it was cross threaded it should be leaking.
I would be thinking drilling a hole across the "nut" part big enough to put a screwdriver through then twisting.
It is plastic, so breaking it is an option.
Get the correct tool for the future. It is listed in the aforementioned Amazon link.
donbrew is offline
Quick Reply: Stuck oil filter cap
