rough idle and engine light on
Old 10-25-2014, 06:37 PM
bluwing's Avatar
Hi,
Need some help. I changed the plugs and air filter today on my 2007 HHR LT 2.2 everything went smooth until I started it up. Have a rough Idle and the check engine light is on.
Everything is connected.. plugs are the same as the originals.
Any help would be great. Need the car for tomorrow and don't have another car to use..
Bluwing
bluwing is offline
Old 10-25-2014, 06:46 PM
Well. You've been a member here long enough to know. If the Check Engine Light is on, you need to have the codes read to point you to the problem and fix.
FWIW. You said everything was connected back. Are you sure ? I would recheck and pay close attention to the MAF sensor plug.
firemangeorge is offline
Old 10-25-2014, 06:55 PM
bluwing's Avatar
Hi Fireman George
Just went and checked the plug again. no change. Where is the negative terminal for the battery?
bluwing is offline
Old 10-25-2014, 07:07 PM
bluwing's Avatar
Hi All,
Need help with this problem!!!
bluwing is offline
Old 10-25-2014, 07:23 PM
Really ? I offered some pretty good advice. Not sure what anyone else can offer up. I guess you don't care about getting the codes read.
No offense, but if you have to ask where the negative terminal is on the battery, maybe you should get someone else to work on your car.
I think I'm done here.
Old 10-25-2014, 07:30 PM
bluwing's Avatar
George,
The parts storeswere closed. No place to have them read. They close at 4 up here on Saturday. would love to have gotten the codes read if possible. HHRs are new to me. If it is right near the fuse box near the firewall, then I am ion the right place...
bluwing is offline
Old 10-25-2014, 07:57 PM
bluwing's Avatar
Sorry George,
I did not know the battery was in the rear... just trying to get this car running for tomorrow. try to reset the computer now. got an hour wait. Thanks for the help.
bluwing is offline
Old 10-25-2014, 08:15 PM
Technical Moderator
Re plug the MAF sensor!!!!!!!!! That is the electrical connection you had to disconnect to get the air filter housing off.
Get an Owners Manual here : https://www.chevyhhr.net/forums/gene...s-manual-3074/
donbrew is offline
Old 10-25-2014, 11:46 PM
Deep breath time folks, no need for tempers to flare, we've had enough of that lately.
As Don recommended, disconnect and reconnect the MAF sensor pigtail, if it didn't seat correctly or if there is some corrosion...you'll have an HHR throwing a fit.
Let us know how you make out bluwing.
843de is offline
Old 10-26-2014, 12:23 AM
hhr06NJ's Avatar
yes, must be corrosion on the connector...
Q: is there a FUSE for that connection?
hhr06NJ is offline
Quick Reply: rough idle and engine light on
