front end alignment specs
Old 11-28-2012, 11:32 AM
alexrckid's Avatar
anyone know what the specs are..?? are caster/camber adjustable or is it just the toe..?? thanks
alexrckid is offline
Old 11-28-2012, 12:29 PM
Do a search here. There was a post not too long with the specs. I think it was posted by ChevyMgr because I ran off a copy.
Camber is adjustable with camber offset bolts.(Moog and some others make them) Parts store should have them. Caster adjustment: No
firemangeorge is offline
Old 11-28-2012, 12:32 PM
Oops. It was still on my desktop.
Old 11-29-2012, 04:40 PM
alexrckid's Avatar
thank you very much.....
Old 11-30-2012, 12:10 AM
[QUOTE=firemangeorge;681699]Oops. It was still on my desktop.
Ha ! Fireman- I was just gonna post the same pic, I saved it too..
sleeper is offline
Old 07-22-2021, 07:18 PM
ScareDe2's Avatar
I got my 2007 HHR with original FE1 suspension checked for alignment today but the mechanic did not find any spec and said the car was all right, almost everything looked green on the screen:
Front camber right : -1.4
Front camber left : -1.5
Front caster right : +3.6
Front caster left: +4.2
Wheel alignment front : +0.15
Rear camber right : +0.1
Rear camber left : +1.0
Wheel alignment rear: +0.08
ScareDe2 is offline
Old 07-22-2021, 08:03 PM
Is there a question here?
The specs are posted above.
RJ_RS_SS_350 is offline
Old 07-22-2021, 08:18 PM
Technical Moderator
The only thing that is adjustable is toe.
donbrew is offline
Old 07-24-2021, 07:07 PM
Gearhead1's Avatar
Fe1….fe3…..
What the difference….I have 2011, HHR LT, 2.2
Gearhead1 is offline
Old 07-24-2021, 08:22 PM
SS is FE5, all others are FE1/FE3.
Quick Reply: front end alignment specs
