trans issues
Old 02-19-2014, 02:38 AM
outlaw's Avatar
trans issues
I figure that this transmission is done but ill get some feed back first.
I just bought this little gem. 1st gear wont pull. Reverse and all of the other gears are fine. I checked the fluid level and its ok.
While going thru the car is found a receipt for some partsfor it and it looks like they put dexron v in it.
Does anyone think that a fluid change will fix it or should i just replace it and be done?
Thanks for all the info.
outlaw is offline
Old 02-19-2014, 04:45 AM
Lucky's Avatar
Welcome to the site Your symptoms sound as if your trans may be in limp in mode. I would go to your local parts store and see if they can get any trouble codes from the computer system.
The codes may help lead to what the problem is
Lucky is offline
Old 02-19-2014, 05:27 AM
Welcome to the site.
Good advice from Lucky.
So. Just to clarify. You are talking about a automatic transmission? Also, what year and the mileage.
firemangeorge is offline
Old 02-19-2014, 02:02 PM
outlaw's Avatar
Its a 2006 with 102,000 there is no check engine light no codes.
outlaw is offline
Old 02-19-2014, 02:40 PM
LawDog88's Avatar
No light doesn't mean no codes....
LawDog88 is offline
Old 02-19-2014, 04:34 PM
Technical Moderator
2006 came with Dex V, however GM changed the recommendation to Dex VI in a TSB. So don't sweat the Dexron part, it's basically a change from dino to syn. But, it might be low if they did not know how to check the level. SEARCH "transmission fluid".
And I'm sure someone will post the drawing of the component locations.
donbrew is offline
Old 02-19-2014, 04:42 PM
Lucky's Avatar
Like this.
Lucky is offline
Old 02-19-2014, 06:01 PM
Welcome outlaw!
Sorry to hear your transmission is giving you troubles. Let me know if there is anything I can look into for you. I can be reached via PM.
Sincerely,
Jonathan A.
Chevrolet Customer Care
ChevroletCustomerService is offline
Old 02-19-2014, 07:09 PM
Technical Moderator
I thought so. Do you keep it on your clipboard?
donbrew is offline
Old 02-19-2014, 08:50 PM
Lucky's Avatar
I keep them in my photo album
Lucky is offline
Quick Reply: trans issues
