Key fob not working at times.
Recently bought a 2009 HHR. The fob is a sometimes fob. Sometimes it works. Sometimes it doesn't. Only one of the three buttons works.... the horn one. On back, says GM/L: 15777636.....
Two questions.
One: Since money is tight for me, what is the most economic way to get a working fob -- repair or replace.
Two: GM or third party?
Two questions.
Two questions.
Two questions.
You can get replacement key fob pads on ebay for a few bucks. some of a our members have glued a small amount of tin foil to the back of the key pad to repair the contact.
Search key fob repair and you will find lots of info.
or......i had the same key fob issue a few years back. sent away for the keyless fix.....never any problem since. super easy install.
Keylessfix - Home
Keylessfix - Home
https://www.chevyhhr.net/forums/comm...ng-find-51706/
That's at NAPA, but all of the stores have a similar supplier. Advance uses Dorman IIRC. They all come from Dorman but each store calls it something different.
Yes, there is a new Dorman, or whatever your choice of store calls the brand, keyfob that includes a program module. I have not tried it, but it claims to work.
