Location of the ambient engine temperature sensor.... Help!
This one little sensor is making my MAF sensor go out and is killing my turbo. The sensor acts up and the MAF sensor kills the turbo, I just found the root problem this morning but I have been unable to locate the sensor on the car itself. 2008 HHR SS
You don't mean the ambient air temperature sensor--that's the one that provides the temperature readout on the D.I.C. You mean the Intake Air Pressure and Temperature Sensor. It's located on the charge air cooler outlet pipe.
But the air temp sensor should be on the passenger side front frame horn behind the fog light hole. In that general area, anyway. On my 2011 LT they moved to the driver side in the lower grill hole.
We can't be talking about that one. What would that sensor have to do with the MAF sensor/turbo?
It was the original Question that nobody wanted to answer. That' why I put "but" at the beginning. I have been taught that ignoring a direct question was bad manners, if if it is the wrong question.
Now that I know which sensor it really is in trying to recreate the problem so I can have the diagnostics done again, but I have gone all over the air intake from top to bottom and can only find one sensor that being the MAF right on top going from the air box to the turbo, am I overlooking the intake pressure sensor?
