Problem with Rear defroster grid- 1 line not working???
well turned on the rear defroster for the first time this year and one of the lines isn't working. Im still under warranty, does anyone know what they will do to fix it?
I suspect they will examine the line to see if some of your cargo has scraped it so that the circuit is open. A real possibility, if so they may wish to charge you for it. OR for customer relations they may repair it for free.
If they cannot find anything in the "exposed" area of the glass, they will remove the trim panel to see if the open is where the trim panel contacts the glass. Another real possibility, if so this maybe a bad design and thus warrantable and arguable - I would.
Most FSM have a procedure of repairing the resistor/heater element. I did not find one in my 2009 FSM.
Take a magnifying glass and examine the line yourself to have a better idea.
They make kits to repair the grids. Here is a link to one
http://www.popularmechanics.com/auto...o/4221212.html
Do you clean the inside of your rear window often? Many times just the act of wiping the window with a cloth or paper towel could damage the heating element. To make sure that you don't cause damage I've always been told to wiping across the window, parallel to the heating elements, so that you minimize the chance of breaking a line.
