Oil in spark plug well
Old 02-28-2014, 09:38 AM
rickschr85051's Avatar
I recently changed my plugs @ 62000 miles and discoverd some oil in the plug well, has anyone seen this? I was also wondering if my plug boot could be effected by oil inside of it? Thanks
rickschr85051 is offline
Old 02-28-2014, 09:44 AM
It happens. Most likely it's the gaskets around the spark plug wells under the valve cover that need to be replaced. Not a major repair nor expense. The spark plug boot should just need a cleaning and will most likely be just fine.
Old 02-28-2014, 10:28 AM
Lucky's Avatar
X2
Lucky is offline
Old 02-28-2014, 04:00 PM
X3!!
Old 02-28-2014, 06:08 PM
X3. The valve cover gasket is actually a multi-piece thing with O-rings at the spark plug holes, if it has ever been removed somebody may not have replaced them correctly.
Old 03-03-2014, 09:20 AM
Thanks for the info!
Old 03-03-2014, 04:51 PM
badassbowtie's Avatar
A sloppy oil change is very likely too!!!
badassbowtie is offline
06chevyHHR
08-22-2014 10:27 AM
pstar
04-30-2014 12:44 AM
hhrpdc
08-14-2012 11:08 AM
kmcrae476
11
08-10-2011 07:15 AM
Quick Reply: Oil in spark plug well
