Intermittent Transmission problem
Old 08-27-2015, 01:32 PM
mike1955's Avatar
2007 HHR LT. About once every 100 miles at low speed the transmission will let completely go like it's in neutral. Cured by downshifting and shifting back to D. Also, at highway speeds (OD) accelerates good unless you floor it which causes it to again completely let loose but every time. Get off the accelerator for a couple seconds and it's back to normal. Shifts and acts normal the rest of the time. A friend checked it on a Tech II - no codes stored. I thought possibly the TCM until we found no codes. Transmission fluid and filter were changed about 6 months ago. I just checked the fluid level - perfect. Any ideas?
mike1955 is offline
Old 08-27-2015, 03:49 PM
Welcome!
Sounds like a bad internal valve to .me. Professional trans shop, sorry.
Wifes07LT
09-03-2013 08:44 PM
Alan Cook
01-25-2012 01:55 PM
Happy13178
12-01-2011 08:30 AM
permafaust
12-21-2009 05:23 PM
mew7789
12-06-2006 01:08 PM
Quick Reply: Intermittent Transmission problem
