Code P0010
Old 08-27-2009, 11:18 AM
mikiec's Avatar
Code P0010
My 06 is showing a P0010 code. Check engine light came on and the Tranny started hard shifting.
I have read up on the code but have no idea how to perform the checks.
Any help would be appreciated.
mike
mikiec is offline
Old 08-27-2009, 01:03 PM
stephenm's Avatar
i found this through google
HTH
HHR has an intermittent P0010 and and even more intermittent p0013. This pertains to intake cam actuator circuit malfuction and intake cam angle performance (not suprisingly) respectively
mike
stephenm is offline
Old 09-16-2009, 05:33 PM
mikiec's Avatar
Cam positioning sensor bank1 replaced. It is located under the air cleaner. All is good.
mike
mikiec is offline
Old 03-24-2012, 06:36 PM
Jam815's Avatar
Question also throwing a p0010...
I read your fix and was curious where did you find the part, also how much did it cost?
I also noticed I think you had the problem in '09, just wondering.
Thanks, Jam
Jam815 is offline
Old 03-26-2012, 08:34 AM
mikiec's Avatar
At that time it was a dealer only item.
Mike
mikiec is offline
Old 03-26-2012, 10:48 AM
If you are referring to the Camshaft Positioning SOLENOIDS (not sensors) see thread https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/ especially at the end where the latest part numbers are detailed.
jlk8911
02-04-2015 01:46 AM
Byroan
03-28-2014 01:30 AM
twrsolar
01-06-2014 02:13 PM
chefan
02-09-2013 07:35 PM
diskullman
10-12-2011 01:40 PM
Quick Reply: Code P0010
