| Problems/Service/Repairs If you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post! |
#1 | ||
Member #: 25467
Posts: 2 |
Another 'Engine Power Reduced' Thread...
#2 |
Hey Wayne, I don't know the answer to your delima but would like to say welcome................
#3 |
Member #: 25467
Posts: 2 |
Thanks...
No one has fixed there own car when they had this issue??? Has anyone ever been shown the corroded ground bar by the tech that fixed theirs? Any thing is helpful. Thanks |
#4 |
Well Wayne its not that somebody hasn't had this same problem here, but maybe you should look in a different area. Since you got a P2135 which is a correlation problem with the throttle body and you might have a P1516 which is an actuator issue with the same part, I'd suspect a bad throttle body. Since your scan tool packed up on you, maybe your first step would be to go to a Pep Boys or Autozone where they can pull the codes for you without charge. Once you have an accurate read on the code/codes you can go forward. Since you've checked the various under dash connections they can probably be eliminated for now. Trust me, these things can frustrate the heck out of you until you nail the problem down. Keep us posted on the codes that turn up and I'm sure the pool of brains here can help you head down the right path. Before I forget, welcome to the group.
We won it, we won it, we won it!!! RDE 2/15/98 "My definition of an intellectual is someone who can listen to the William Tell Overture without thinking of the Lone Ranger." - Billy Connolly 4 HHR's(2011 "Boo Boo", 2007 "Paddington", 2007 "Bob 2", 2006 "Spousemobile") |
#5 |
Member #: 4571
Posts: 188 |
Reduced engine power can be caused by as simple a condition as battery drained down. It doesn't matter how old the battery is. It is caused by heavy winter electrical loads and short trips. Happened to me last winter. Happened to me this winter - in Yukon. Can happen in Ohio, too.
Be sure to check battery voltage or better yet a battery load test .... or charge it anyway.
---------- 2008 2LT Panel ----------
#6 |
Here in ohio we have had some cold weather so having the battery load tested sounds like a good idea and a good plsce to start. I have not had this problem but I have followed some of the post on this problem I still don't have a clear understanding of what fails on the trottle body but there seems to be alot of them getting replaced so I understand your confushion. welcome to the site lots of good info here good luck hope you get it figured out soon.
#7 |
Member #: 3417
Posts: 10 |
just happened to me 15 minutes ago - if it is the battery, what code will it throw?
#8 |
Member #: 3417
Posts: 10 |
In my case, they are telling me it is the throttle body issue...they "cleaned" the TB, but if it happens again - $180 for the part.
Honestly, for my buying a 1st year production 2006 HHR LT1 with 7 miles on it, and the only other issues being the rotors and a sagging rear wiper, I can't complain. |
#9 |
Member #: 20183
Posts: 54 |
Happened to my 06 LT last week when it was about 12 degrees and according to Autozone, code was throttle body related. Swaped my battery out and drove it for two days with the temperature outside being in the fiftys and it ran great, I think it even ran smoother than it ever had. So yesterday temp in Dallas dropped back down to single digits and due to icing in roads I didn't use it. Today we are in the 12-14 degree range and this morning it happened again on my way to work. Is there a posibility that my battery could have gone out again? Or can it be something related to my heater since both times it has done it, I've had the heat on????
#10 | |
Member #: 3417
Posts: 10 |
| Thread Tools | |
| Display Modes | |
