South Central TX, OK, AR, LA
Oil Type 5W40 - Austin Tx
Old 09-17-2018, 12:16 PM
princesspoohbear00's Avatar
I have a 2009 HHR with 150,000 miles. Can I use 5W40 in my car.
princesspoohbear00 is offline
Old 09-17-2018, 12:23 PM
Technical Moderator
Why? The recommended weight is 5W30.
donbrew is offline
Old 09-17-2018, 01:29 PM
I made this post because I have some 5W40 in my garage and just wanted to know if I could use it in my car. I wanted to get rid of it.
Old 09-17-2018, 01:39 PM
Technical Moderator
I wouldn't use it for the long run, but for 1 cycle it shouldn't hurt. If you suddenly get a CEL, that is probably the cause, the VVT valves are not comfortable with the higher weight.
donbrew is offline
Old 09-17-2018, 01:44 PM
Thank you Donbrew. I think I'll pass from using it at all. Appreciate the comment.
M.Harper
08-03-2009 07:21 PM
steveshow
2.0L Performance Tech
20
04-03-2009 07:32 PM
Ronzo
South Central
18
12-15-2008 01:26 PM
steelwoolghandi
South Central
10-13-2008 02:06 PM
Ronzo
South Central
0
11-17-2006 02:45 PM
Quick Reply: Oil Type 5W40 - Austin Tx
