Boost misfire
Welcome to the site.
Pull the codes from the OBD system and see if it shows any trouble related ones. Post them here if it has any.
Stating the mileage would also help.
Actuator solenoid. Just 1 or both of them ?
PO100 mass air flow circuit fault
123k miles
Intake cam solenoid
You didn't think that the CEL was worth mentioning?
It is P zero 100.
https://www.obd-codes.com/p0100
Was the air filter been replaced just before this started?
It is P zero 100.
