No rpm in neutral
Old 03-20-2017, 06:00 PM
cuba1952's Avatar
Exclamation No rpm in neutral
As you can tell by the title my hhrss09 when in neutral will not go to high rpm and starts sputtering. Any help out there?
cuba1952 is offline
Old 03-20-2017, 06:05 PM
Technical Moderator
I moved your post to a new thread.
donbrew is offline
Old 03-20-2017, 06:09 PM
Moved this from an 8 year old dead thread!
The usual questions pop into my head, any codes? If there are , what are they?
Any changes lately, any wires moved around, any loose connections??
Oldblue is offline
Old 03-20-2017, 06:34 PM
Snoopy's Avatar
What are you considering as "high RPM"?? If IRC, these cars have a rev limiter, in neutral and pushing up through the gears. Could that be what you are recognizing? Have you been able to achieve the high RPM's previously?
Snoopy is offline
Old 03-20-2017, 06:41 PM
DrLoch's Avatar
Haven't said if it's an automatic or a stick. I just looked at a file and in neutral or park it's 3000 RPM form the factory. As snoppy asked, what is considered high RPM?
DrLoch is online now
Old 03-20-2017, 06:58 PM
The sputtering does sound like it could be a rev limiter.
RJ_RS_SS_350 is online now
Old 03-20-2017, 08:36 PM
aradmahogany's Avatar
Definitely ref limiter. I agree. Now stop trying to impress your friends by revving it while stationary and impress them revving it in motion! Also IDK if it makes a difference but my 2006 2.4 is limited to 4000in park or neutral!
aradmahogany is offline
Old 03-20-2017, 08:37 PM
celblazer's Avatar
Agree it might be a rev limiter or I know my Trifecta has the option to change the launch control RPM setting.
celblazer is offline
Old 03-22-2017, 01:56 PM
Hmmm... just tried it in my 09 SS, went to full redline, very quickly, I might add
Cuba, what RPM are you getting to? You may have a problem after all. I have a manual trans.
urbexHHR
08-19-2009 04:10 PM
COOKZ32
08-06-2008 12:34 PM
Quick Reply: No rpm in neutral
