Tire Pressure Monitor - Don't Want
Old 03-27-2013, 11:10 AM
racer-ray's Avatar
I'm putting different Solstace rims on my 2009 HHR SS and was considering having normal valve stems installed. Will this just cause a Tire Pressure Monitoring system code to be constantly activated? Will this cause some kind of computer error that will not allow the vehicle to run properly?
Thanks, Ray in TX.
racer-ray is offline
Old 03-27-2013, 11:14 AM
skyline26's Avatar
you will just have the dash light and "service tpms system" message on DIC which you can clear, but cant clear the dash light.
This will not harm the car in any way, but it may eventually burn out the bulb..which i heard is not replaceable and have to get the whole unit replaced..but im not sure on that
I do this with my winter tires but my summers have the sensors
skyline26 is offline
Old 03-27-2013, 04:05 PM
hyperv6's Avatar
Just do yourself a favor and get the sensors as they are not that expensive if you shop around. The aftermarket has now offered them.
hyperv6 is offline
Old 03-27-2013, 07:30 PM
Sno White's Avatar
Don't know, but do the OEM TPM not fit the new rims. If they fit just move them over.
Sno White is offline
Old 03-27-2013, 08:05 PM
skyline26's Avatar
can anyone suggest any aftermarkets? i tried a set off a cobalt from the same year and they didnt sync up
Old 03-27-2013, 08:45 PM
towcar2000's Avatar
Tire Pressure Monitors
States that have vehicle inspection will not pass inspection on vehicles that have TPM as factory installed items unless they are operative so I have been told. My 2-cents. Bill
towcar2000 is offline
Old 03-27-2013, 09:00 PM
Snoopy's Avatar
I have a small recollection about removing the tire pressure monitors. But before I mention it, I have a question.......just to double check.......
Has anybody completely removed the monitors and drive without them?
Snoopy is offline
Old 03-28-2013, 10:50 AM
Sno White's Avatar
See post #2 of this thread for your answer.
Old 03-28-2013, 10:52 AM
Sno White's Avatar
When I got my winter tires and rims Tire Rack was happy to sell me some and I am happy with them. Don't recall the cost.
Old 03-28-2013, 11:21 AM
Snoopy's Avatar
Sno white.....I guess I originally misread his post....Thanks.
Skyline.......interpeting your post, as you DO RUN your winter tires/wheels WITHOUT tire pressure sensors linked to your car. Is this correct?? If so, did you receive other codes or problems, at any time just after, maybe not directly AFTER, BUT A REASONABLE TIME AFTER, your wheel install?
Snoopy is offline
Quick Reply: Tire Pressure Monitor - Don't Want
