J. Hunto's Garage - HHR Maintenance Videos
Old 01-22-2017, 11:24 PM
JohnHHR's Avatar
Everything HHR
HOW TO CHANGE A RADIATOR HOSE: INSPECTION AND REPLACEMENT:
THERMOSTAT CHANGE:
P0016 & P0017, BLUE DRIVER SCAN TOOL IN ACTION:
P0016/17 and how to change a TIMING CHAIN:
Changing front struts:
Turn signal magic:
JohnHHR is offline
Old 08-07-2017, 08:00 PM
JohnHHR's Avatar
HHR Oil Cooler
Video from J. Hunto's Garage.
JohnHHR is offline
Old 08-07-2017, 08:52 PM
https://www.youtube.com/watch?v=K5NiyO_y6dI
Thanks for documenting this John. It looks like the damage may have been caused by the prior wrenching? You said you had already removed this a time or 2.
Oil cooler was on early 2006 2.4 engine, but also on all the 2.0 SS's.
Here's a link to a thread where a member had relocated the cooler. I never understood the logic, the O-rings are still down there, and they're still going to go bad. Maybe that plate is easier to remove than the cooler. For anyone interested, here's the link
https://www.chevyhhr.net/forums/prob...located-52605/
RJ_RS_SS_350 is offline
Old 08-07-2017, 10:08 PM
You have posted 5 times, as far as I can tell, click bait postings. I should not be difficult to find where to post them.
To find your posts:
donbrew is offline
Old 08-07-2017, 10:40 PM
JohnHHR's Avatar
Oil Cooler
That is quite possible. Watch for part 2. The permanent fix!
JohnHHR is offline
JohnHHR
Mods - Engine/Exhaust
09-23-2016 07:00 AM
DYLANSHHR
08-15-2006 04:36 AM
Quick Reply: J. Hunto's Garage - HHR Maintenance Videos
