22 psi - yellow or green spring
Old Aug 23, 2012 | 01:45 PM
Wolfblitz's Avatar
Mods are listed in my sig, have a tune now though. HP Tuned on 22 psi. Was wondering if I should stick with the green spring or go to the yellow. Want to up to 26 psi after meth. Need everyone's input, thanks
Old Aug 23, 2012 | 01:47 PM
Breadfan's Avatar
Should be fine with green. Is easy to try the yellow and switch back if you get a CEL or turbo flutter.
Old Aug 23, 2012 | 02:13 PM
moonsign's Avatar
I'm Trifecta tuned, and on the Forge valve, I'm using yellow spring, with no problems, and I sure don't baby it. "Moon"
Old Aug 23, 2012 | 02:20 PM
Breadfan's Avatar
I should add that I'm on the yellow myself at around 23psi. It seemed to work just fine so I never bothered to put the green back in. Can hear occasional flutter when I run without airbox lid but no CEL.
Old Aug 23, 2012 | 04:26 PM
ChevyGuySS's Avatar
im curios too, im at about 25 psi, what spring should i use?
Old Aug 23, 2012 | 04:49 PM
Yellow, for me, I'm around 25lbs.
Old Aug 23, 2012 | 04:58 PM
Yellow, for me, I'm around 25lbs. I have the red and blue if you need a stiffer one.
Old Aug 24, 2012 | 12:32 PM
andyb's Avatar
Post
the only mod's i have are the GM tune upgrade & the magnaflow catback exhaust. i installed the forge valve w/ the yellow spring & now the "check engine" comes on after hard accel while already moving - 2nd or 3rd gear. does anyone have a green spring they want to get rid off?
Old Aug 24, 2012 | 02:10 PM
Didn't your forge valve come with both the yellow and green spring?
Old Aug 24, 2012 | 08:45 PM
XtremeSS's Avatar
I used to use the yellow spring...but I think that the Green is a "safer" choice. It has been stated that others are using green on 20-25 psi with no problems holding pressure. Turbo flutter=not good
