22psi stock tune.
I had the plastic fittings on my stock intercooler break and ran without boast for a week and now have the zzp intercooler on. For about 2 weeks after the install it was holding at 22.5 psi not just spiking and spooling a lot faster. It is now back to normal at 19 psi. Has anyone else had something like this happen and is there any way to get the 22.5 psi back or do I just need to turn it.
Sorry, but 22psi, where you live at, is not a stock tune. If you bought the car new and can verify it's stock, then you either have a faulty gauge or a BV problem. If it is stock, then it would(should) trigger an overboost CEL with boost numbers that high.
If you bought it used, then the previous owner probably had a tune done. Fwiw. Around 19 is what I get with the GMTU. I'm pretty close to sea level like you are. Your's sounds like those are GMTU numbers. |
Quick way to verify; look at the top of the MAP sensors and see if the sensor is marked with a sticker. Blue and white sticker means 3 bar MAP sensor and GMTU.
1 Attachment(s)
Originally Posted by gamma-wes
(Post 760682)
Attachment 16634 |
(Post 760663)
Nope. Mine has pulled 19 since day 1 of the GMTU install. It has nothing to do with any of that learn down theory.
I have had several back and forth talks with some engineers at GM regarding this. In a nutshell, if it's making the power with 19 lbs, then that's all I'll get according to them. The RPD does show my output to be right at the GMTU's 290hp, 315tq. |
(Post 760731)
There's no 'learn down"
Our ECMs are "torque-based". Whatever the "torque-curve" is, in the "tune", is what the ECM is going to do it's best, to follow. The GMTU, + all aftermarket "tunes", of course, have better "torque-curves",than stock. The ECM "learns" quickly, after being reset , to settle into it's programmed "torque-curve". That's why, with even a bone stock HHR SS, the 1st few minutes after an ECM reset, your buggy will fly. If you reset your ECM at the track, your next run down the track will probaby be your best run of the day...:twothumbs: |
The car is back to 22.5 psi and has been there for 2 days now. I'm guessing it is actually already tuned because I noticed the cruise control button got bumped off and that was the first time it was off since I got the car and I know some tunes us it to turn on. I bought the car used by the way.
Originally Posted by 2005HHRauto
(Post 760845)
