Originally Posted by bmx racer
(Post 760855)
The car is back to 22.5 psi and has been there for 2 days now. I'm guessing it is actually already tuned because I noticed the cruise control button got bumped off and that was the first time it was off since I got the car and I know some tunes us it to turn on. I bought the car used by the way.
Did you look to see if you have the Bosch sensor like in the picture I posted ? |
Originally Posted by XtremeSS
(Post 760860)
"Torque based parameters adjustment"s , "learn down"- same same lol
Think of the ECM as being "wide-open", in an "out-of-control" state, in the neutral zone, with all the tables frantically, trying to get in sync with each other, to deliver the desired "torque-curve", that the ECM was programmed for. The ECM will quickly, achieve control. If we had a NA engine, you wouldn't notice this taking place. Put your E47 program into a bone stock HHR SS , with a few parameters reset for gasoline, & the ECM will try it's best to deliver the same "torque-curve", that you have now, on E47, & you'll never feel it's trying to reset to a lower "torque-curve', as it will be constantly tring to reset to a much higher "torque-curve", that it will never achieve. I've done this, & it's really awesome. When driving my E47 "tune", on gasoline, it feels exactly the same as when on E47, up to at least half throttle. With just cruising around town, or going to work, it's the same..:twothumbs: The ECM is easily doing this, by smoothly increasing the boost. I tryed this, incase of a scenario, in which I didn't have access to Ethanol. It really makes sense, as it's the Ethanol that's giving us the awesome power & torque increase. |
Originally Posted by 2005HHRauto
(Post 760876)
No
Then with the example that I gave, it will be a "learn-up", & will never
reach the higher programmed, "torque-curve". Learn up or down, the ECM is just syncing it's tables, to best follow the programmed "torque-curve"...:twothumbs: If you do feel a nice increase in power with an ECM reset, it just means that your "tune", not as strong as it could be, there's room for improvement. |
(Post 760926)
