Adm Enhanced Gm Stage Tune
Maxboost
It went overly rich up top.On the street it does not do this on the wideband,only on the dyno.
Same with the boost-On the street it can almost maintain maxed out Map,But on the dyno it falls from max(255kpa) to 224 at 6500rpm.
Hope this helps!
Hope this helps!
I've tried to follow all of the different posts,
However I have a few questions.
1. 297whp and 354wtrq with the unmodified gm tune and all your goodies sans adm tune, will that power last or will the computer tune out/pull back on those numbers after some time/miles back to 290HP and 315trq (quite a significant difference considering crank vs wheel number comparison).
2. Did/would you get any codes, assuming/if you ran a cat.
