Anyone running meth yet?
Old Nov 26, 2011 | 07:15 AM
RobSSTurbo's Avatar
I am looking to run meth kit just got BYT TB spacer and was wondering if anyone installed one yet? If so do got pics of your install cause I would like know were a great place to mount the pump.
Old Nov 26, 2011 | 12:26 PM
ATLsilverSS's Avatar
i have the spacer but haven't got the meth kit yet....had some things come up.
the pump should be mounted near the tank...so you are using a small tank under the hood or in the fender, mount the pump nearest the tank. if you are using a larger tank and mounting it in the back, then mount the pump near the tank in the back.
i don't know if there is any room behind the bumper or in the fender well with the hhr (i know you can mount one there in a cobalt). i was gonna mount a large tank in the hatch area and mount the pump on the tank (devils own)
Old Nov 27, 2011 | 05:00 PM
RobSSTurbo's Avatar
i was thinking of taping into the washer tank and mount the pump next to it or below it.
Old Nov 27, 2011 | 06:36 PM
fwiw devils own says not to mount the pump near heat so i would think that would rule out mounting under the hood.
Old Nov 27, 2011 | 08:50 PM
RobSSTurbo's Avatar
Hmm well I'll just may have to mount it in the rear.
Old Nov 27, 2011 | 09:11 PM
i believe you are also supposed to mount the pump within a couple feet from the tank....so i guess that means a rear mount tank too. this is kinda what i ran into when i was about to buy my kit.
here is what i was going to do:
-devils own dvc30 stg 2 kit
-devils own 2.25 gal sumped tank (can mount pump to tank)
-devils own upgraded solenoid
-devils own stainless lines
mount the pump to the tank. remove spare tire and the cover that screws down ontop of it. mount tank in spare tire well. cover with the top thick cover to a stock like look. i measured and it will fit if you remove that bottom cover.
HHRSSouth
2.0L Performance Tech
Jun 2, 2011 03:37 PM
krh0003
30
May 10, 2010 09:47 PM
xzombiex66
Jul 29, 2009 04:58 PM
MOTRV8D
Nov 9, 2006 03:37 PM
