Anyone running the Modern Performance DP?
Old May 23, 2010 | 01:56 PM
txbass06's Avatar
Originally Posted by BoostedSS
Thanks guys, But the DP is for the Cobalt SS/TC, It will fit fine?
Yes. Headers and DP's will interchange between the HHR and Balt
Old May 23, 2010 | 06:10 PM
2005HHRauto's Avatar
https://www.chevyhhr.net/forums/hhr-ss-45/cobalt-dp-29654/
YES for the 5 speed trans, they all interchange.
HHR auto DP is 1" longer, also the HHR auto 1st cat is in a slightly different location & angle.
A 5 speed factory DP in an auto HHR will have the 1st cat slightly rubbing againest the sway bar. And the stock cat-back will rub at the gas tank, unless you add 1" in length of the cat-back in the resonator section of the stock cat-back.
The Magnaflow cat-back will work ok, no adjustment needed.
excellent 'all-you-need-to-know' thread on downpipes.
http://www.cobaltss.net/forums/showthread.php?t=198998
Old May 24, 2010 | 07:18 AM
Jeff®'s Avatar
Originally Posted by SmootHHR
IDK, I guess we could make a "glossary" of sorts and sticky? IMO this makes me LOL. DP FTW
The HHR is made in Mexico...
Old May 25, 2010 | 01:25 AM
BoostedSS's Avatar
Originally Posted by 2005HHRauto
https://www.chevyhhr.net/forums/showthread.php?t=29654
So what do i do when i order the DP since it needs to be 1" longer since i'm auto?
Old May 25, 2010 | 02:04 PM
You have to add an inch in the stock catback in the resonator straight section,
or in the DP you order. You can ask your DP maker to add an inch.
Old May 25, 2010 | 11:05 PM
BoostedSS's Avatar
So if im doing just the DP i need to ask Modern Performance to add 1inch to the length of their downpipe since i'm automatic?
This seems to be more a pain than it's worth since i can't buy parts that bolt right up, Damn auto
Old May 27, 2010 | 12:43 PM
asanti's Avatar
Honestly, just make sure you tell them that it's going into an HHR SS w/ an auto tranny when you place your order. It's that simple!! Take a look in my gallery as I have pics of the exhaust install and you can see how the DP fits (well, Hahn's version anyway lol). I knew NOTHING of "shorter or longer" DP's when I ordered mine last year and haven't had any issues with the DP hitting the sway bar (I don't see how that's possible?? but W/E) nor any rubbing up front. Like I said before the only issue I had was with the hanger over the axle slipping off, but I fixed that and haven't had any more issues. My cat back has never rubbed/hit the gas tank either. Just my .02. Like I said, make it clear what it's going into when you order and you should be fine.
Later
Allex
eaglefreak138
Tires & Wheels
Sep 16, 2011 09:45 AM
racer-ray
Jun 27, 2010 08:01 AM
xzombiex66
Jul 29, 2009 04:58 PM
Don Juan
2.2L Performance Tech
10
Mar 13, 2008 06:28 AM
ymerej_mortsdnil
Feb 21, 2007 09:05 AM
