Boost Question with launch control and WOT
Old Mar 27, 2010 | 09:24 AM
HHRSSouth's Avatar
Originally Posted by IgottaWoody
I think alot of people are confusing the older turbo systems that basically held boost until whatever limits were reached, especially since bost pressures were low compared to the SS...where as the SS willl and does vary/regulate the boost and output power by means of timing and boost to keep the engine in one piece and make that 100k warranty possible...
^^^^This
Old Mar 27, 2010 | 10:43 AM
asanti's Avatar
Agreed x2! I can relate since after installing the new IC and piping I've noticed that boost in 1st gear has tapered off to 10lbs, then it'll go up to 15lbs. I'm one of those folks that's getting used to the "variable" boost on the SS vs the more traditional way of seeing a boost gauge peg at a certain psi and stay there until someone shifts into another gear (like say an SRT4).
Later
Allex
Old Mar 29, 2010 | 09:50 PM
Mercury's Avatar
My car doesn't build boost for launch control though.
I can recall it doing so previously.
I found a video of it: http://www.youtube.com/watch?v=mhmGd...eature=related
Old Mar 30, 2010 | 07:57 PM
got2boostit2's Avatar
Originally Posted by hyperv6
I think at times the best thing that GM could have done is left the boost gauge out off the car. There is no reason to have one unless you modify the engine.
Also if you do not know how the system works it only creates more issues and questions.
Exactly......it was the same way when they added the information systems years ago! Just generated a bunch of complaints as people had no clue how they operated! Dealers should have the ability to set them to "stupid" mode. IMHO of course!
Reminds me of a story.....Da wifey and a girlfriend had me in tow on one of their trips and I kept saying "idiot light". The girlfriend wanted to know why I called warning lights "idiot lights", I calmly replied so any idiot would know that something is wrong with the car. I was able to ride undisturbed for the remainder of the trip as she was highly offended! I don't know why?
Old Mar 31, 2010 | 06:06 PM
hyperv6's Avatar
Even idiot light is not a good term. I knew a girl once who put tape over one of her lights. Her dad saw it and asked why it was there, she said it was shinning in her eyes at night. He pulled it off and it was the oil light. Thank God Toyota used bad sending units as this engine would have been toast.
Old Apr 1, 2010 | 06:51 AM
mistermike's Avatar
Originally Posted by Mercury
I thought the stage 1 upgrade makes a minimum of 22psi?
Wrong.
Boost is the measure of air that DIDN'T make it into the engine. It will vary with temperature, throttle position, engine load, cam phasing, RPM, and astrological sign.
Old Apr 1, 2010 | 07:55 AM
foolmoon_design's Avatar
Originally Posted by mistermike
Wrong.
So a car under the sign of Picses will out run a Gemini?
Old Apr 1, 2010 | 08:01 AM
gcsd3742's Avatar
I doubt it isint the sign Gemini 2 so with that being said you'd have to out run 2 or do better than 2? Or it could mean just the opposite they have twice the issues?
Old Apr 1, 2010 | 09:42 AM
mp928's Avatar
Wrong.
But the sticker that comes with the kit and placed in the correct area for all to see, should fix all of this.
Old Apr 1, 2010 | 10:13 PM
IgottaWoody's Avatar
Yes! And if you outline it with a ( color of your choice) Sharpie, its good for an additional 1 lb of boost pressure on a full moon at high tide.......
