BSR PPE or Stage one GM
Old Dec 22, 2010 | 11:44 AM
71corvette's Avatar
Found this plug in tuner from BSR, seems to have a higher HP change than the GM stage 1. Torbo Tech and Hahn is selling them now, The price is higher than the GM unit even with install costs, but the claims are higher than GM. Opinions?
For manual or automatic, nothing else even comes close to the ease of this plug-and-play solution:
No need to remove your PCM and send it across the nation while your car sits
Easy return to stock in minutes
Much more power than noisy, flamboyant air intake and exhaust upgrades
Less hassle about warranty work than loud and apparent exhaust and intake mods
Takes full advantage of the excellent performance your stock exhaust and airbox are able to provide
More power per dollar increase than any other modification you can make!
MSRP $1199.00, Your cost: only $995.99!
Chevrolet HHR SS 2.0T 260HpPower figuresoriginalStage 1power:260Hp312Hptorque:353Nm439Nm
Average power increase: 41Hp or 19.2%Accelerationkm/hgearorigStage 1%80-12035.44.41980-14049.28.112100-15049.18.111
Tested with manual gearbox.
Old Dec 22, 2010 | 11:59 AM
Sunflowerhippi's Avatar
I am confused. What specs does this tuner get your car to?
(http://www.gmpartshouse.com/products...grade-kit.html)
Gm's kit puts the car at:
•290HP @ 5,200 RPM
•315 lb,-ft of torque @ 4,800
Are you saying this kit goes from 260 + "Average power increase: 41Hp" to 301? So 11 more then the GM kit?
Really to me 11hp is not worth voiding my warentee, plus HP tuners or a Trifecta tune (one of the vendors on here) is cheaper and from what I have read Trifecta tunes are 300+hp as well and would be much cheaper then $995.
Old Dec 22, 2010 | 01:18 PM
rallycobalt06's Avatar
GM kit is covered under warranty & gives you needed sensors.
BSR hand held tuner...... is just flash tune & sucks.
get the GM stage one, if you want more power.... add bolt ons.... still want more power.... get a custom HPTuners tune. i see you're in CT, i can recommend some tuners/shops in your area if you'd like.
Old Dec 22, 2010 | 01:37 PM
bartSS's Avatar
Forget the BSR tune is all i got to say
Old Dec 22, 2010 | 02:08 PM
Mrs. DLVRNIT's Avatar
We have friends with SS HHR's that have done the GM Stage install and others the Trifecta Tune! From what we've been told the Trifecta was painless to install and has almost the same final dyno numbers at around $300.00!
https://www.chwtunecenter.com/
Best-O-Luck ,
Old Dec 23, 2010 | 07:19 AM
bartSS's Avatar
Then they did a weak trifecta tune lol
Old Jan 3, 2011 | 08:34 AM
71corvette's Avatar
Sounds good send me what you got on tuners in the area. Thanks
Old Jan 3, 2011 | 12:26 PM
from what i'm hearing a lot of the Cobalt guys in CT are going to SMG Motorsports in Hopedale, MA.
Old Jan 3, 2011 | 07:16 PM
foolmoon_design's Avatar
Avoid BSR. They have been out for 3 years with no additional tunes, or product support. If your gonna tune over the GMTU. then try a trifecta tune. a bunch of the forum members have been really happy with this additional tune
Old Jan 5, 2011 | 08:28 AM
mightymouse's Avatar
i say stay FAR away from the gm tune. i never thought about getting it. i read about more people having trouble out of that tune than anything. trifecta is the way to go. however,the more upgrades u have,the better the trifecta will be. if you upgrade your clutch,you can get a really strong trifecta tune.
