Dyno results
Direct Injection is the reason for the lean out... Read into direct injection tech to see. I thought the same thing as i am working on a turbo project for my Jeep. then I read up on the difference direct injection makes and I had the old light bulb pop on. There is actually a slight cooling of intake air because of mixing in cylinder, and the mix is better. Allows for a leaner ratio for efficency.
Dyno stock no Mods
Had dyno today stock no Mods
Max power = 244.67
Max torque = 250.04
Should be about 286.26 at the flywheel, it's a little lein
Having a problem attaching Dyno sheets, will post to my gallery tonight or tomorrow.
Next Mod Stage 1 in a couple weeks then back to the Dyno
Let me know if this is good, bad or the norm for stock
Byron
Max power = 244.67
Max torque = 250.04
Byron
