Ethanol 101 , The best performance fuel for your HHR SS
Old Aug 17, 2012 | 08:09 PM
  #31
Breadfan's Avatar
Let me put it this way, if you get on the go-stick a lot, you'll be lucky to make 300 miles before a bone-dry tank.
Old Aug 17, 2012 | 08:47 PM
  #32
2005HHRauto's Avatar
Originally Posted by SS Panel
2005HHRauto, I want to thank you for sharing your E-47 Tune, all I can say is unbeliveable, with HPTuner we can run the tune to match the type of fuel in the tank, glad I didn't go with Trifecta.
Corn whiskey is just awesome...
Smooth power increase, with gobs of torque...
Plus an E47 tune, is an excellent 'canned" tune,
as it can be used 'as is', with little, or no changes needed...
Old Aug 17, 2012 | 09:56 PM
  #33
RobSSTurbo's Avatar
May want to tune for the maf every car is different.
Old Aug 21, 2012 | 11:26 AM
  #34
Victory Red SS's Avatar
Originally Posted by russruth
I wanted the 1-2 shift done but Vince can't do that on a 2008, only a 2009 and I asked for a few more things, but haven't heard from him in a month.
IMO
P.S. In all fairness I think Vince does a pretty good job, it just seems he has a lot on his plate. Doing it again, (if I did it again), I'd go to a tuner that had access to a dyno and could dial the car in themselves, then check everything, then make changes.
The only thing I want is a little more boost and that dreaded 1-2 kick off that happens either under torque management or hitting the rev limiter. I'm not sure which it is, but I know it's not good for the car to blast off the line, then have a complete engine shut down, then back on at 100%.
They're has to be a smoother way to do this.
IMO
Yes, with HPTuners under the 'Trans" tab. Try it, you'll like it.
Old Aug 21, 2012 | 11:29 AM
  #35
Originally Posted by RobSSTurbo
If you want to switch back to 93 or 91 you well have to run the tank dry and fill up with 93 then load the tune for 93. Then car well run like carp for little bit and it well be back to normal.
I know! I hate it when my car runs like carp. Plus that nasty fish smell...
A Crazy Canuck
Fuel Economy - Hypermiling
23
Jan 11, 2013 06:29 PM
bigjacksauto
2.0L Performance Tech
18
Jul 25, 2012 10:40 AM
BADBOY
14
Jul 27, 2011 02:30 PM
mikey12561
21
Jul 21, 2010 11:40 AM
rockNroad
2.4L Performance Tech
Apr 21, 2007 10:03 PM
