GM Performance Parts Turbo Upgrade Kit
Old Dec 19, 2008 | 06:54 PM
  #181
Chevy SS's Avatar
Nice I know a guy at my dealer, hopefully I can get it at cost or cost +5% or something.
Old Dec 19, 2008 | 07:12 PM
  #182
This upgrade has some of the Ford boys at another forum I frequent a little upset
"Its already bad enough I cant keep up with a minivan... now this?!" spatakula - 2002 Ford Focus SVT #602
Old Dec 19, 2008 | 07:55 PM
  #183
turbofreak's Avatar
§ Solstice and Sky Manual = 290HP@5200RPM / 340TQ@3600RPM
§ Solstice Automatic = 290HP@5200RPM / 325TQ@3600RPM
§ HHR Manual or Auto = 290HP@5200RPM / 315TQ@4800RPM[/COLOR][/QUOTE]
Bill,
Could you comment on the reason for the lower torque output of the FWD
HHR SS versions vs the 25 ft# higher torque rating of the RWD Solstice
versions. I suspect the clutch is the limiting factor as I am guessing the RWD
clutch is stronger. Can you confirm??
I am running a tune on HHR SS 5 spd with about 100 ft# more than stock
and the clutch slips a little in high gear at max torque of about 3200 rpm.
Not unhappy- just trying to confirm the weak link.
Thanks for your posts and solid info.
turbofreak
retired engineer GM road race programs
Old Dec 19, 2008 | 08:01 PM
  #184
WaGoN MOnger's Avatar
limitations of the f35 tranny... the transmission in the fwd can only hold 320ft lbs of torque so 315 is right on the limit.
Old Dec 19, 2008 | 10:34 PM
  #185
405HP_Z06's Avatar
Bill,
Can I install everything in the kit and then drive to the dealer and have the PCM flashed? I would rather solder the connections for the new sensor connectors. I'm not sure if the car will run with the new sensors without the new PCM flash.
Thanks for all the good info.
Old Dec 20, 2008 | 12:14 AM
  #186
Originally Posted by 405HP_Z06
Bill,
he said earlier it would not and the car may go into limp mode...
Old Dec 20, 2008 | 06:56 AM
  #187
ADM PERFORMANCE's Avatar
Former Sponsor
Bill,
Runs fine as long as you drive normal.....fuel trims will be slightly negative.
Old Dec 20, 2008 | 10:08 AM
  #188
405HP_Z06's Avatar
Thanks Andy!
Old Dec 20, 2008 | 07:48 PM
  #189
More_Torque_More_HP's Avatar
Bill,
turbofreak
The differences do not have anything to do with the clutches. The differences are due to the FWD driveline vs the RWD driveline capabilities.
Old Dec 20, 2008 | 07:57 PM
  #190
Instal Kit and Then Drive to the Dealer?
Bill,
I do not recommend doing this. It may cause codes and conditions you do not want. My recommendation for the home installers is to trailer the car to your dealer.
