Hahn, Dejon, or ZZP. Whats the best
I am no expert but I would expect the silicone to stretch under high boost pressure therefore causing more boost lag or less boost in general, but like I said I am no expert. If anyone has more knowledge on this please feel free to clear the air.
Can I use the ZZP with the stock airbox and is it worth it to use silicone? I haven't really looked at the hot side pipe but have trimmed the cold side rubber coupling at the IC to slide it forward and give the MAP more clearance from the AC comp. I tried to remove it from the pipe but had no success.
I called Dan @ CIA and he was more than helpful. He talked with me for about a 1/2 hour. It was pleasure to deal with him. If his product is as perfect as customer service then I don't see why anyone would chose another company for their boost piping. I mean the piping is 100% mandrel bent, comes with silicone couplers and t-bolt clamps, and ALL the piping is powdercoated to boot.
ZZP intercooler will be here by Monday and piping will be here next Friday(have to wait for the powder coat). Needless to say I am very excited for this install.
Thanks to everyone who gave me input on this subject. DP, exhaust, and trifecta next
No problem. I think C.I.A. has the best boost piping available. As you know, it has one less coupler which not only means one less joint for a boost leak, it is a much cleaner look installed. Just make sure you have the T-Bolts tight before you drive it. If not, a dent in the hood will occur. Cold side is a pain in the ass but they all are, even the stock.
Be patient, their shipping can be a little slow but the product is top notch.
Good luck!
Good luck!
wow,these threads on which is the best... i can honestly say my hahn stuff fit with no problems. my pipes do what they are suppose to and not crack.i live in an area of extreme weather too. last feb we had a high of 18 for almost a week. this summer we got as high as 108-120 heat index. my end tanks have yet to crack. set up been on car for almost 3 years and no problems.
my best advice to ANYONE is:
1. you get what you pay for
2. who or whatever you decide,try to keep everything in the same family. makes it easier to get things fixed or replaced. what i mean by that is,one company can't blame the other for the failed part.when ALL of the parts come from the same manuf.,there is no/little wiggle room.
