Heat soaked IC piping
Oh right. I know what a catch can does, I was just looking for more information about making one from an air compressor filter. I could google, but since you have experience in the matter....
Also, I wouldn't think that N/A Ecotecs have this issue, but since I'm running 22+psi, maybe? Better safe than sorry.
A material that more readily transfers heat from the surrounding hot air may not be the most desireable for intake plumbing. A lower thermal mass is usually good, as it will recover quicker from heating. Generally plastics work pretty well in these applications, because they neither store nor transfer heat particularly well. My measurements using thermistors in the intake tract show insulation around the plumbing to be quite effective regardless of the underlying material.
