Heat soaked IC piping
Old Jan 5, 2009 | 07:54 PM
XXL's Avatar
XXL
Originally Posted by mightymouse
from what i understand the hahn piping does not carry alot of heat as it is not made of aluminum.
Heat transfer coefficient of aluminum is much better in Aluminum.
coeff. (k=Wm-1K-1)
carbon steel = 50
stainless steel = 25
aluminium = 237
Old Jan 5, 2009 | 08:33 PM
camaro98z28's Avatar
coeff. (k=Wm-1K-1)
carbon steel = 50
aluminium = 237
Copper or Gold would be better. I agree Aluminum would be best to work with.
Old Jan 6, 2009 | 09:46 AM
mistermike's Avatar
Originally Posted by AaronSS
Oh right. I know what a catch can does, I was just looking for more information about making one from an air compressor filter. I could google, but since you have experience in the matter....
Also, I wouldn't think that N/A Ecotecs have this issue, but since I'm running 22+psi, maybe? Better safe than sorry.
It's pretty straightforward. Just insert the filter in the main vacuum line in the PCV circuit. It's usually a port somewhere on the intake manifold. With a pressurized intake such as ours, it may be routed differently or possibly have a check valve. Since I'm just learning this engine, I'll defer to people with service data and more experience.
Old Jan 6, 2009 | 09:54 AM
mistermike's Avatar
coeff. (k=Wm-1K-1)
carbon steel = 50
aluminium = 237
A material that more readily transfers heat from the surrounding hot air may not be the most desireable for intake plumbing. A lower thermal mass is usually good, as it will recover quicker from heating. Generally plastics work pretty well in these applications, because they neither store nor transfer heat particularly well. My measurements using thermistors in the intake tract show insulation around the plumbing to be quite effective regardless of the underlying material.
Macklady15
Drivetrain (Excluding Engine)
Dec 10, 2013 06:28 PM
stanvalp
May 19, 2011 12:16 PM
greg.may12
Jun 11, 2010 10:59 AM
Nebulous1
Sep 20, 2008 12:27 AM
keverz146
Jan 11, 2008 10:20 AM
