How much boost from the stage 1?
And is this is in certain gears? My max, every time...no matter what...seriously, in second gear is 19. In third it was about 18 or 18.5. I haven't tried other gears. Second is the easiest to check in regular driving.
I hit 24 psi in 2nd gear this morning (holy torque steer batman), but on average wot shifting get about 20-22 psi with occasional 24 psi spike. Heck I hit 20 psi in 1st yesterday, but 1st goes so fast it almost useless to go wot starting in 1st. I almost have it figured out in 1st gear where to hold the throttle to hit 12-15 psi for launching.
I've had my Stage kit in for about 1 1/2 weeks. In normal driving I get around 16psi unless I gun it from 30-40mph then I'll see 24ish psi. In comp mode with the tranny in either "D" or "I" I'll see 24 psi easily. From a dead stop I'll spin 1st and second then hang on for dear life lol. Waterbury CT by the way.
Later
Allex
Later
Allex
Later
Allex
Later
Allex
Ok this is weird, but after 20 times of trying the turbo and maxing at 19, I hit 21-22. It was a farily hot day when it happened and my numbers never seem to have correlated with temp. thus far. What I did do this time, was try turbo (in 1st, 2nd, and 3rd) and tried all three gears in all three modes. I went from pinned at 19 to 22. Maybe this is part of the "unlearning/relearning". Not sure. It could be coincidence, but I suggest if anyone out there is getting lower numbers than people are suggesting...21 to 24...and have never seen those numbers...try what I said...its worth a shot.
Up until that point I had only hit turbo in 2,3,4 gear in regular mode. I had never hit turbo in the other modes (after the upgrade kit that is).
gmdealerguy
2.0L Performance Tech
33
Jul 28, 2010 02:30 PM
