How To Verify Stage Upgrade?
Old Jun 3, 2011 | 09:40 AM
pnad's Avatar
Hey guys, quick question about stage upgrade kits.
Looking at a used 08 SS. I noticed the upgrade sticker on the intake, part number 19212670.
It is an automatic. Is there easy way to verify the kit is still installed? Boost levels? Will I be able to see the 4pin MAP sensor easily?
Thanks
Old Jun 3, 2011 | 10:02 AM
Vcode455's Avatar
You can tell by the seat of your pants if you've drive both stage and non-stage versions!
Old Jun 3, 2011 | 10:32 AM
pitbull76's Avatar
Thanks
If it boosts anywhere near 20psi(or higher), it has the upgrade.
Old Jun 3, 2011 | 10:33 AM
Victory Red SS's Avatar
Thanks
You should see more than 15 psi on hard throttle. I see 20-23 usually. Also, open the hood and look at the upper sensor it's under a 3/8" black A/C line on the right hand side of the engine on top. It should only have one screw holding it down. The lower one is very hard to see.
Old Jun 3, 2011 | 10:43 AM
pnad's Avatar
Thanks guys
Old Jun 3, 2011 | 10:53 AM
asanti's Avatar
Adding to what V.R. SS said, the upper MAP sensor you can see will have a blue Bosch sticker on it and will have WHITE wires coming out of it. That's the dead giveaway.
Later
Allex
Old Jun 3, 2011 | 11:22 AM
stephenm's Avatar
Go by the upper map sensor and not the boost guage
Old Jun 25, 2011 | 01:18 PM
raminator01's Avatar
would either one of you be able to provide a picture of this? i am wondering if my car has one as well.
Old Jun 27, 2011 | 10:07 AM
asanti's Avatar
It's a little hard to see here, but the upper sensor has the blue + white sticker, it's sitting under the vaccuum line at the bottom of the pic. For reference look just below the lower right bolt on the airbox and you'll kinda see it.
FURIOUS10
Mid Central
16
Jul 25, 2011 08:15 PM
Doctor Who
2.0L Performance Tech
18
Mar 5, 2011 02:04 PM
ICE SS
Dec 28, 2009 07:26 AM
OVRBOOST
Dec 3, 2009 11:57 PM
