I need to control the boost
Old Jul 14, 2011 | 01:00 PM
ATLsilverSS's Avatar
Could be a boost leak or bad sensors like I said. Do u have hp tuners still?
Old Jul 14, 2011 | 01:01 PM
If u could send me a log my buddy can look at it
Old Jul 14, 2011 | 01:02 PM
What other mods are on the car?
Old Jul 14, 2011 | 02:55 PM
Spozo's Avatar
When the adjusting nuts back off, generally you loose boost... To adjust it, I find it easier to go by the top. Remove the 3 10mm holding on the heat shield, then use a deep socket on a 1/4" ratchet with a back up wrench, if I remember right, it's 10mm too.
To adjust it, loosen them right off, tighten the outside one until you just start to feel spring tension, then tighten it 3 more turns, use the other nut to lock it in place. If the outside one turns during the tightening, you should start over. Then use loctite to keep them in place.
Sounds more to me like the wastegate is sticking than an adjustment though, check that first.
Old Jul 14, 2011 | 03:11 PM
camaro98z28's Avatar
No other mods. Im not sure where my HP tuner is. I will put it up on ramps and look at the wastegate. I wonder if it is messed up.
Old Jul 14, 2011 | 04:20 PM
if you can find the hp tuners and use the vcm scanner to log about a 30 minute drive with stop n go, wide open throttle, redline (if you can get there safely).......various driving conditions especially those that replicate the symptoms, that will help diagnose a LOT
Old Jul 14, 2011 | 04:21 PM
it could come from fueling, airflow, timing, etc, which in turn could be a sensor, boost leak, timing problem who knows......like i said a log would help a lot
Old Jul 14, 2011 | 04:23 PM
I say from the bottom cause you can see everything from there....the wastegate, the rod, the lines, the bypass valve, etc to see if anything is out of place
Old Jul 14, 2011 | 04:50 PM
Spozo's Avatar
Whatever floats your boat.
Old Jul 14, 2011 | 06:07 PM
right
