Installing an Oil Catch Can
Old 06-17-2017, 06:18 PM
  #351
2 Rogers don't make a right..... but when you throw a Clarence in also... Yeah I'm good with that!!
RJ_RS_SS_350 is offline
Old 06-17-2017, 07:55 PM
  #352
And the spoils go to the Victor!
Oldblue is offline
Old 06-23-2017, 12:42 AM
  #353
Yeah, images are still wonky, I didn't see Victor until just now.
Old 08-09-2017, 03:22 PM
  #354
Okay, finally drove enough miles to drain the cans again, and compare to last time. Much less fluid caught than the previous times.
3 oz. turbo-side, and 9 oz. intake-side. 107,810 miles. So again, about 1200 miles.
It's hard to compare apples to oranges. The weather has dried up, so not as much moisture in the air, not as much moisture in the incoming air stream to catch.
Old 08-09-2017, 03:51 PM
  #355
So long as it's catching it, awesome!
Oldblue is offline
Old 10-22-2017, 11:57 AM
  #356
Drained the cans again just now. 5 oz. turbo-side, and 10 oz. intake-side.
108,917 so a little early, but close to 1200 miles.
Old 11-18-2017, 05:12 PM
  #357
Another drain day, I'm at 110,400 miles, so nearly 1300 miles. I'm trying to stay around 1200 miles between drains, for comparison purposes.
9 oz. turbo-side, and 18 oz. intake-side.
Old 11-24-2017, 01:35 PM
  #358
Cat Man HHR's Avatar
Randy
I'm not going back to day one when this started. But what do you think was the real advantage of your pluming?
I know to relocate the PCV and run it to a catch can plumbed into the intake manifold.
The turbo line is a gray area to me.
From what I see doing just the PCV mod is the biggest advantage.
Cat Man HHR is offline
Old 11-24-2017, 01:53 PM
  #359
True, that is the biggest advantage, as I am catching more liquid in that line. But I am also catching a significant amount in the turbo line.
The liquid in the intake line would have gone straight to the valves(coking, poor compression) and the combustion chambers(carbon deposits, pre-ignition, super-knock).
The liquid in the turbo line would probably mostly deposit in the turbo, charge piping, and - the intercooler(higher intake air temps, pre-ignition). Some may also make it to the throttle body, the valves and combustion chambers.
So I think both systems are important.
Old 11-24-2017, 03:24 PM
  #360
Please re-post your system diagram with out the extra catch cans please.
I know my fault is using the K&N intake pipe that has no check valve.
Wonder if 2005HHR has a choking problem? As he doesn't talk about an external PCV system.
Quick Reply: Installing an Oil Catch Can
