Installing an Oil Catch Can
RJ, I'm trying to understand your routing. Where are you feeding the catch can from, the manifold PCV valve check valve? It must be an old guy thing
As far as a good check valve look here, Intercooler Pipe Fabrication Not very expensive and they do work well.
Those check valves look good. I found a few on Amazon that look like they're the same, but there always seemed to be a few reviews that said they just didn't work. I didn't want to take a chance, dealing with returns, shipping charges, yadda yadda. Sourced locally - under $5, no shipping, easy returns, and I knew I could easily modify it to fit.
Nice setup RJ, your research will be vital to my installation! I started the install of the upgraded fuel lobe cam. I pulled the cam, tried to hold the timing but it jumped off the crankshaft! So, once I get back home I'll be pulling the front cover to reset timing....yay!
This is what I'm working on, Whitewater Rafting in OKC | Boathouse District we are doing the headgate system using water as the fluid medium hydraulics.
RJ, I have 2 of those checks that I sent you the link on, one 3/8" hose barb the other 5/16" hose barb. FWIW they are zero leak, I wouldn't consider as a replacement of the intake PCV though.
Understand that one.
Not sure how that applies catman! Lol, jury is out on that one.
I'm thinking about just starting off with a vacuum pump. Then I don't even need the darn hole I drilled in my turbo (hind sight). For the LHU, LDK crowd we can utilize an exhaust cam driven pump. Which was factory installed on the some Buick's.
For those with the LNF (Gen2) variable I found a little vacuum pump here;
2009 - 2010 Chevy HHR Brake Electric Vacuum Pump from SPEED Manufacturing
It claims that it's for an HHR. I'm calling BS! That's OK, you'll just need a good 12V source and your good to go. Looks pretty small.
Here's a link for the LDK/LHU crowd. The part in question isn't pictured but it's at the bottom of the page. I think for 150 bucks having a constant vacuum is worth it.
HYDRAULIC SYSTEM for 2013 Buick Regal
Hella Street Vacuum Pumps 009428087 - Free Shipping on Orders Over $99 at Summit Racing
-Catman, you can get pre cut SS screens for tubing from McMaster. I'm building my cans almost entirely from them.
- Nice doc, that's a start
- Good deal RJ, I just came across that one looking for the Buick's part #. Like I said, it's BS anyway. There was no vacuum pump on an hhr! I like cheaper!
