It's amazing, that a piece of plastic tubing, can make such a big difference...
Old Mar 10, 2015 | 12:24 PM
Some of these buggys are temperamental about the intake.....read the code and we will know....Usually a P101 when it don't like the intake.
Old Mar 10, 2015 | 01:06 PM
UnderBoosted's Avatar
Sounds good, I'll pull the code after work & see what it comes back with.
Old Mar 10, 2015 | 06:41 PM
Originally Posted by UnderBoosted
Would the K&N filter cause the "check engine" light to come on? My father just called me & told me the light showed up, & was planning on leaving work early to have some daylight to check it.
If it's new, yes. If it's over oiled yes.
I think SSFan meant P0101.
Old Mar 11, 2015 | 09:06 AM
Still waiting to get the code pulled, left work pretty late last night so no where to take it.
Old Mar 11, 2015 | 10:13 AM
that's ok we'll wait!!
Old Mar 11, 2015 | 01:47 PM
DrLoch's Avatar
Especially if it's oiled.. If that is the case I would 1st do the MAF cleaner thing and try it again.
Old Mar 12, 2015 | 09:04 AM
breds2k's Avatar
hmm you guys have me thinking about this! Would I be able to install this with my ZZP intake before tuning? Im on GMS1 now and have a clutch issue, so I cant retune until that's taken care of in a few weeks (ky stage 3). Ive been staring at the intake for a few weeks itching to get it on. I have the stock airbox lid off and am getting a maf code now so I want to get it taken care of (hate having the lid on)
Old Mar 17, 2015 | 06:40 PM
Cat Man HHR's Avatar
Hi
As a science project I just ordered the intake tube and "breather" fitting from K&N for my SS.
I have silicone reducer coupler's from another project I did that I got from Ebay.
I'm using the stock round air cleaner. I've read some articles about air cleaner performance and air flow isn't that much different between OEM and K&N filters, if anything at all.
Called K&N at 800-858 3333 and ordered:
P/N 087147A Intake tube $40.99
P/N 08938 Breather tube fitting $5.58
Will it make a difference? Don't know until I install it.
Can't see spending $250 when it cost me like $47.00 shipped.
Thanks
Old Mar 18, 2015 | 10:22 AM
and that's what I call hot rodding! changing parts to improve performance, sometimes it works sometimes it doesn't. I went with an idea from other members for more air getting to the air filter I drilled the appropriate sized hole in the driver's side of my 2.2 stock air box and used ABS plumbing 2" pipe and a coupler salvaged the ends of my destroyed wolleyworm ( thanks GM tech guy!) and ran it to the area just above the rad for cold air supply, (no, not that Air Supply) its not an SS but some members may find this helps
Old Mar 18, 2015 | 10:34 AM
2005HHRauto's Avatar
Originally Posted by Cat Man HHR
Hi
Thanks
YES..
http://www.knfilters.com/instructions/63-3069_inst.pdf
Some other guys have done the same thing.
That tube WILL, make a big difference in everyday driving, with nice,
crisp, throttle response...
I'm going to order, another intake tube, just for a spare...
