Quaife 6 Speed Gearkit, Feedback Anyone?
Old Jan 25, 2008 | 08:38 PM
jeffs396's Avatar
Originally Posted by jonboyb
There's several threads over on the Cobalt SS forums with discussions about the F35 and F40 gearboxes. Several discussions regarding the F35 cases cracking (and apparently at the same location). Sent some messages trying to get more info
I see on the http://media.gm.com/us/powertrain/en...2008/08car.htm site that the F40 six speed is used on Saab 2.0L combinations, I didn't think the 4 cylinder block bolt pattern was the same as the V6 pattern that this transaxle is used on? I've got an F40 here at home that I'm using for a 3.1L V6 in a Beretta. Maybe GM didn't use this six speed in the SS because it requires an intermediate shaft & equal length axles, requiring mods to the HHR engine cradle/suspension?
Old Jan 29, 2008 | 05:24 PM
sHHRs's Avatar
From what I understand, it is no easy task to swap in the F40. It has a different bolt pattern on the bell housing, different axles, and a different shift mechanism. No thanks. I'm still very interested in the Quaife six speed conversion for the F35. If only I knew why the cases were breaking....
I wonder if the Quaife conversion makes the tranny stronger by reason of the two extra bearings that support the ends of the shafts outside of sixth gear? I'll bet that makes a difference, and limits shaft flex.
Old Jan 30, 2008 | 08:36 PM
c2vette's Avatar
From this specification it looks like a stock SS is right at the torque rating of the F35. Probably conservative, still....I wonder how much more we can safely boost the power: http://www.gminsidenews.com/index.php?page=trans_guide
Old Feb 6, 2008 | 01:49 PM
Copperhead's Avatar
Originally Posted by JoeR
A 6 speed would likely lose acceleration due to the broad torque curve of the LNF with VVT.
As far a "The gearbox scares me....", so it does GM! That's why they incorporated "launch control" and "no lift shift", which are nothing more that nanny controls to prevent abuse and subsequent warranty claims.
I swear just a few months ago I read where Chevy tried the SS with a 6 spd gear box and it slow the car down. Thats why they opted for the 5 spd. I can see that with a turbo car.
Old Feb 6, 2008 | 10:56 PM
hhrcrafty's Avatar
I wonder if it's because of the solid motor and trans mounts people are installing to "get robbed power back"...
F35 will probably take a lot more power and abuse than it's rated for. Just have to be smart in how you use it.
Old Dec 21, 2008 | 05:33 PM
c2vette's Avatar
So now that I have lived with the SS for almost 20,000 miles, I really can see that the 6 speed would be a very nice upgrade. First gets taller (3.00) vs 3.38 stock, which is good since 1st seems too short in most folks opinion I believe, 2nd and 3rd are shorter than stock which means 3rd would be very useful for tight back roads where I find 3rd a bit too tall. Third gear pull with the tune (GM or Hahn/PPC) would be even better than it is now (which is fantastic)! Now slight problem is still almost $4,000. to do this swap.
Old Dec 21, 2008 | 06:14 PM
XXL's Avatar
XXL
I recall reading a snippet on one of the Cobalt boards that you lose reverse. I tried to contact Quaife via email for clarification but never got a response.
Old Dec 21, 2008 | 07:32 PM
c2vette's Avatar
Hmm, now that would be a problem .
Old Dec 21, 2008 | 08:04 PM
XXL's Avatar
XXL
OK, maybe not. I was surfing my way to their site again to send them another query on the subject when I found the following on cobaltss.net...
5-Speed FGP F35 Transmission using Quaife's 6-Speed conversion:
Type: Transverse front wheel drive, five-speed manual transaxle ( Optional with limited slip differential )
Engine range: 2.0L I-4 supercharged
Maximum engine torque: 200 lb-ft ( 271 Nm)
Maximum gearbox torque: 258 lb-ft ( 350 Nm )
Wheel+Tire Circumference: 2044mm
Gear ratios: MU3
First: 2.72
Second: 1.89
Third: 1.368
Fourth: 1.045
Fifth: 0.833
Sixth: 0.704
Reverse: 3.17
Final Drive Ratio: 4.04
So... never mind
Old Dec 21, 2008 | 08:18 PM
IgottaWoody's Avatar
Yup..looks like a good trans for a closed course....no real benefit on the street other then bragging rights and having to shift more. The main reason for more gears is to maintain torque peak,something not lacking in this little motor.
