Quaife 6 Speed Gearkit, Feedback Anyone?
Old Dec 21, 2008 | 08:34 PM
AaronSS's Avatar
Worthless mod for a show car. Second doesn't need to be shorter, as I spin through most of it as is. With a little more power, third will be the same way.
Old Dec 21, 2008 | 09:29 PM
c2vette's Avatar
Originally Posted by XXL
OK, maybe not. I was surfing my way to their site again to send them another query on the subject when I found the following on cobaltss.net...
5-Speed FGP F35 Transmission using Quaife's 6-Speed conversion:
Type: Transverse front wheel drive, five-speed manual transaxle ( Optional with limited slip differential )
Engine range: 2.0L I-4 supercharged
Maximum engine torque: 200 lb-ft ( 271 Nm)
Maximum gearbox torque: 258 lb-ft ( 350 Nm )
Wheel+Tire Circumference: 2044mm
Gear ratios: MU3
First: 2.72
Second: 1.89
Third: 1.368
Fourth: 1.045
Fifth: 0.833
Sixth: 0.704
Reverse: 3.17
Final Drive Ratio: 4.04
So... never mind
These ratios seem to be different, wonder what the actual specs are. http://www.turbotechracing.com/produ...idproduct=5076
Old Dec 21, 2008 | 09:33 PM
c2vette's Avatar
Tough to say, third gear tops out before the end of the 1/4, so would times be faster with closer ratios and the same number of shifts? A lot of experiments with 3 gears to 7 with 4-stroke MX bikes and also cars, seems like in general 6 speeds has been where most perf vehicles end up turbo or otherwise.
Old Dec 22, 2008 | 11:49 AM
camaro98z28's Avatar
Thats why we can up the rev limit 200 to 400 rpms more and still be in 3rd going through the traps.
Old Dec 22, 2008 | 02:56 PM
Unclesams_SS's Avatar
Originally Posted by sHHRs
No, I think you've got that wrong. Seems to me that if you wanted maximum acceleration capability, especially with the broad, flat torque curve of our motors, then this gear kit would certainly be the way to go. With the same torque, but better gearing, you will pull harder, and acclerate faster. And yes, the Quaife kit is undoubtedly stronger.
Where have people been breaking their cases?
I cracked mine wide open @ 7200 miles With just DR's on.
Old Dec 22, 2008 | 03:12 PM
  #26
Clevelandhhrss's Avatar
Hi unclesams,
Would you elaborate on the circumstances, or give any knowledge that you have with "cracked cases"?. I'm sure many here would like to know.
Thanks.
Old Dec 22, 2008 | 03:46 PM
  #27
WaGoN MOnger's Avatar
its possible to do but very exspensive...you would have to change the final drive ratio too or your gears would be extremly short. Now the only reason this would be of use is gas mileage ,it would drop your rpm lower at higher speeds... not really help your performance at all except add a extra gear change which would probaly slow you down.
When these cars were being tested the engineer form gm said that the cars were slower with a 6 speed so this a expsensive mod with very little gain. I can find the ;inl on the cobalt forums if needed.
Old Dec 22, 2008 | 04:44 PM
  #28
AaronSS's Avatar
Exactly. Get HP Tuners and that won't be an issue.
With that said, I'd like to revise my statement.
It's a worthless mod for show cars IF YOU REMAIN ON STOCK TURBO
If you were running a big, laggy turbo, say a GT35 (journal bearing), I could see the benefit.
Old Dec 22, 2008 | 08:42 PM
  #29
c2vette's Avatar
I have the HPTuners and the Hahn/PPC tune, but I was talked out of raising the rpm limit in 3rd gear by someone with more experience than me with these drivelines due to possible durability considerations with 3rd gear and high rpm/horsepower. If I was actually competing for best 1/4 mile time I would definitely do it though as that last shift definitely costs time (although I don't think 400 rpm would be enough to avoid the shift). As far as the 6 speed, the cost/possible_benefit is not there for me or most folks.
Old Mar 5, 2009 | 11:56 AM
  #30
sHHRs's Avatar
anyone bite the bullet yet on this kit?
