Stage 1 Changes??
Old Mar 20, 2012 | 04:10 PM
RBodeman's Avatar
Originally Posted by IgottaWoody
make sure its not your motor mounts..the auto's do this too...Dealer says its not right but mother GM wont replace unless they are broken....which is why the stage guys are having wiring problems..too much slop and too tight clearance
Motor mounts? And that will cause a clunking sound even with normal light shifts at a cruising speed?
How do I check the mounts?
The two dealerships I have been to did not have any HHR SS 5spds to compare it to.
Old Mar 28, 2012 | 08:05 PM
87silver's Avatar
RE GM Turbo Upgrade Warrantee:
Originally Posted by Vcode455
I have 3 yrs warranty on mine too. Definitely a worthwhile upgrade, especially on my auto. As far as expensive, where else will you find a 55 hp, factory warrantied upgrade for $6-700? I promise you, NOWHERE! BMW, M-B, and Volvo all charge thousands of $$$ for their factory upgrades. This is a downright STEAL!
Re warrantee, the lower BOSCH TMAP sensor (part of the kit) went out on mine a few months back, at about 31k mi/37 months. The dealer charged me about $200 to replace it (parts & labor) because it was slightly over the calendar BTB warranty. I went to GM customer service and put in a claim and they opened a case. After they had done their due diligence with the case, they refunded me the entire cost, parts and labor. When they say that the GM Turbo Upgrade kit falls under the new car warranty, from my practical experience I found that GM stands behind it.
Old Apr 13, 2012 | 08:18 PM
RBodeman's Avatar
Does anyone know the time changes this "stage 1" will have on an SS 5spd?
Old Apr 13, 2012 | 10:18 PM
87silver's Avatar
RBodeman, if you want to find a dealer who is a master at the LNF and not crazy far from you, try the one in Newburgh, NY but make sure you ask for Travis. If he's not the technician who works on your SS, it'll be wrong, so insist.
I had my GM Turbo Upgrade kit installed by him almost 3 years/33k miles ago and except for a sensor failing (not the wiring, but the BOSCH sensor itself; not his fault; it was a component failure), all has been well. The failed sensor reduced boost to 5psi, but didn't leave me stranded.
And Travis used the dreaded "crimps" that most technicians don't know how to install, but he had the right die and torch (I wonder how many dangerous vehicles are out there with airbags repaired with these "approved" crimps from inept technicians). He also modified the clearance between the compressor and the lower sensor connector.
BTW, the sensor was about a month out of warrantee when it failed, and GM still covered it.
Doctor Who
2.0L Performance Tech
Nov 2, 2011 12:44 PM
Miltown SS
15
Apr 11, 2011 11:33 AM
JRGHHRSS08
17
Feb 23, 2011 12:19 PM
Sandmanse7en
18
Nov 21, 2009 09:21 PM
camaro98z28
30
Jan 6, 2009 10:07 PM
