Stage Kit Horsepower Increase for Automatic
Check the following link.........
https://www.chevyhhr.net/forums/2-0l-performance-tech-46/gm-shows-love-290hp-340ftlb-upgrade-%24650-20074/
As stated before... The Automatic see the greatest improvment for the $$ spent. We get almost 50HP! When I picked mine up, it was like a whole new car. 10-15HP makes your "Butt-Dyno" look really hard for the added punch.
50HP makes it Pucker!
Also, do you need a tune after getting the stage kit? I bought my 09 SS wrecked and it came with 17" alloys that I plan on upgrading to 18"s like it should have came with in the next year when the OEM tires wear out.
No, you don't need a tune afterwards, although there are some aftermarkets available and can void any warranty you may have.
I paid $285 off ebay for my kit. $100 for the install.
I downloaded this .pdf and brought it to the appointment
http://www.sandyblogs.com/techlink/t...k_April_09.pdf
went over everything with the tech for the install.
these are the highlights.
1. The tech was the Vette Tech.. this is important i think because of the confined space to work in.
2. he did not remove the charge pipes. (It was a pain in the ass, he raised and lowered the car 20 times) but he felt removing them would have caused more headaches.. some people have had to have their IC moved during the install.
3. It is important to point out the Boss removal.. it is easily overlooked.
4. It took 3 hours. book calls for 1 1/2 to 2 I think.
5 You MUST use the proper crimp tool and they must know how to use it properly. If they don't you will have headaches.
