Super 16G or Super 20G
Old Jul 8, 2012 | 07:57 PM
RobSSTurbo's Avatar
Originally Posted by 08SSREDHHR
Rob are you using 3 bar sensors?
yup my ss had the gm stage 1 kit on it already when i got it.
Old Jul 8, 2012 | 08:05 PM
Breadfan's Avatar
I try to limit my tune to the max psi of the sensor range. I could drop ~$85 on the 3 bar, but with the stock turbo, you are pushing it out of its optimum range pretty soon after about 25psi anyway. If I ever decided to go with a bigger turbo, the 3 bars would be great since I could push a higher psi without as much heat.
Old Jul 8, 2012 | 08:08 PM
08SSREDHHR's Avatar
Originally Posted by RobSSTurbo
oh sweet, I learn something everyday. Ill prolly pick these up...thanks
Old Jul 8, 2012 | 10:33 PM
ChevyGuySS's Avatar
Old Jul 9, 2012 | 12:00 AM
XtremeSS's Avatar
Why don't you just go with an e-tune and zzp cams with larger fuel lobe? Your total will probly cost less than a Grand.
Old Jul 9, 2012 | 10:08 AM
Wolfblitz's Avatar
Thanks Rob, that was a good read
Old Jul 9, 2012 | 06:56 PM
JAXFL_SS's Avatar
So, for those of you in the know, what would be the good and bad of going this route over the turbo swap (or prior to)? The ZZP site shows good gains for the cost.
After my new clutch goes in in a couple of weeks, I won't do anything further than a full bore tune until sometime next year, but I guess its a good time to plan for the future.
rocketmangb
Feb 9, 2009 09:38 PM
Lone Ranger
Sep 11, 2007 10:03 PM
NHHHR
Jun 8, 2007 10:55 PM
ymerej_mortsdnil
Jan 25, 2007 07:39 AM
