Trifecta Budget Tune
Old Feb 17, 2011 | 01:56 PM
bartSS's Avatar
Do an HPTune you will like it better
Old Feb 17, 2011 | 02:13 PM
09 Silver Bullett's Avatar
Originally Posted by asanti
Funny quick story: I HAD a set of Hahn pipes on before w/ T-bolts bro. All the connections were on tight, but the hotside connection blew off @ the intercooler after I had them on for a few weeks w/ no problems. I fixed + tightened the crap out of that connection only to have it blow off again 2 days later. I got pissed since I had to get to work the next day, so I slapped the OEM hotside pipe back on, traded the Hahn pipes for my Aeroforce gauges and didn't have another problem till last week that I posted up. Granted I bought another set of Hahn pipes and am just waiting for better weather to install them (i.e. nice enough to clean out the garage so I'm not layin in wintry crud!) so I'll make sure all connections are tight and retighten them after a few hundred miles to make sure they STAY that way.
Later
Allex
I had to purchase a new T-bolt clamp, next size smaller, for the connection you are talking about. Seems as though the silicone couplers that are supplied with most charge piping kits are a hair larger than stock intercooler pipe size. I didn't take a chance of it blowing off because I did not drive it until I changed the clamp. If the clamp is drawn all the way down as far as it will go, you should purchase the next size smaller for it.
Old Feb 17, 2011 | 02:26 PM
bartSS's Avatar
One of mine barely got the screw through over the coupler haha its a good size. And its on the ic too
Old Feb 17, 2011 | 03:46 PM
Yeah, it seems that the after market intercooler manufacturers make the intercoolers with little smaller diameter pipe than the stock intercoolers have. I don't know about the Crazy Steve, Hahn or Dejon intercoolers but some Cobalt T/C guys say ZZP & MPX are slightly smaller.
Old Feb 17, 2011 | 04:20 PM
Whats the difference I thought they work together Trifecta program and HP application of tune ?? I know nothing but I have bought nothing yet but it is next and the sales are starting finally!!
Old Feb 17, 2011 | 08:17 PM
  #26
bartSS's Avatar
You can do the trifecta with HPTuners on top of that. I like my HPtune better because i got my car street tuned so i just trust it more. I mean vince does great work by all means i just didnt want to mess with datalogging and sending files back and forth you know.
Old Feb 18, 2011 | 12:21 AM
  #27
Isn't it easy plug in computer & drive it, well mine runs pretty good now and isn't blowing any thing off might just leave it alone !
Old Feb 18, 2011 | 07:31 AM
  #28
bartSS's Avatar
Vince sends you a base flash and yeah you load it to your ECU and then he likes you to log it just in case there is anything else that he needs to tweak. With the street tune i got it took 4 hours of ripping on the car on the highway and such to get it right and dialed in
Old Feb 18, 2011 | 07:59 AM
  #29
Have you done the dyno Vince has shops around here that you can go to and they run it on dyno I guess to do the tweeking. He also said it wasn't necessary, By now they should know what it needs to start with. It's probably the mods that can require tweaking the tune. Mine doesn't have any except the exhaust.oops and K&N filter,and stg-1
Old Feb 18, 2011 | 10:11 AM
  #30
TomsHHR's Avatar
Vince owns a SS that he has done a lot of the adjustments to know what your SS will do.
I have not seen a HPTuners dyno sheet as of yet. But remember if the HPTuners tune is better, why would it do better on top of a Trifecta tune HP base tune?
Just asking.
