Turbo maintenance and tips
Old Jul 15, 2008 | 03:12 PM
Jeda13's Avatar
Good thread! I bought an SS last week and it is my first turbo as well.
JIm
Old Jul 15, 2008 | 03:15 PM
Originally Posted by EcoBoost
We use these methods:
  1. In regular driving, no cool down needed.
  2. If you were JUST on the throttle hard, do not just come to a stop and turn the key off. Let the turbo speed stabilize and some of the temperature in it dissipate...idling for 30 seconds or so is all it takes.
  3. If you've been beating the car mercilessly, such as canyon-carving, track days or autocross, let it run a few minutes before you shut her down. You can even do this on a 'cool-down' lap...so long as you've been driving at cruising-type conditions for a minute or three, it has the same effect as letting her idle. Fact is, it's even a little better than idling, for the somewhat higher RPM helps move coolant and air through the turbo and engine more effectively, as well as air moving across the radiator and intercooler assist in the objective.
Even non-turbo cars benefit from #3...it's very sensible to let your engine and driveline stabilize a bit after severe use. Race cars take cool-down laps for this very reason
Warm-ups are always a good idea before applying heavy loads. Lubrication flows better, and all components in the engine are at the correct 'size' when warm. Thermal expansion as the engine achieves operating temperature changes many subtle aspects of the engine, from ultimate bearing size to actual clamp loads on critical areas like head gaskets.
For these reasons, it's never prudent to run any engine hard before it's at full operating temperature. It's good for the driveline too!
You can just go. The best bet is to just be gentle with her until she warms up.
1st Turbo here too. Thanks for the tips
Old Jul 15, 2008 | 08:55 PM
a76marine's Avatar
And my first turbo as well... will be subscribing to this thread.
oldracer
Maintenance and Upkeep
10
Mar 29, 2015 06:33 PM
jtriker
Oct 8, 2013 03:00 PM
gtsigaridis
Mar 22, 2012 06:31 PM
afs9
2.4L Performance Tech
Jan 26, 2010 09:16 PM
